Display RADIUS CoA Statistics
Use this procedure to display information about RADIUS CoA statistics.
- Select RADIUS CoA.
- Select the CoA Stats tab.
CoA Stats Field Descriptions
Use the data in the following table to use the CoA Stats tab.
Name |
Description |
AddressType |
Specifies the RADIUS Dynamic Authorization Client IP address type. |
Address |
Specifies the RADIUS Dynamic Authorization Client IP address. |
DisconRequests |
Specifies the number of RADIUS Disconnect-Requests received from this Dynamic Authorization Client. This also includes the Disconnect requests that have a Service-Type attribute with a value of Authorize Only. |
DisconAuthOnlyRequests |
Specifies the number of RADIUS Disconnect-Requests that include a Service-Type attribute with value Authorize Only received from this Dynamic Authorization Client. |
DupDisconRequests |
Specifies the number of duplicate RADIUS Disconnect-Request packets received from this Dynamic Authorization Client. |
DisconAcks |
Specifies the number of RADIUS Disconnect-ACK packets sent to this Dynamic Authorization Client. |
DisconNaks |
Specifies the number of RADIUS Disconnect-ACK packets sent to this Dynamic Authorization Client. This includes the RADIUS Disconnect-ACK packets sent with a Service-Type attribute value of Authorize Only, and the RADIUS Disconnect-ACK packets sent because no session context was found. |
DisconNakAuthOnlyRequests |
Specifies the number of RADIUS Disconnect-NAK packets that include a Service-Type attribute with a value of Authorize Only sent to this Dynamic Authorization Client. |
DisconNakSessNoContext |
Specifies the number of RADIUS Disconnect-NAK packets sent to this Dynamic Authorization Client because no session context was found. |
DisconUserSessRemoved |
Specifies the number of user sessions removed for the Disconnect-Requests received from this Dynamic Authorization Client. Depending on site-specific policies, a single Disconnect-Request can change the authorization of multiple user sessions. In cases where the Dynamic Authorization Server has no knowledge of the number of user sessions that are affected by a single request, each Disconnect-Request counts as a single affected user session. |
MalformedDisconRequests |
Specifies the number of malformed RADIUS Disconnect-Request packets received from the Dynamic Authorization Client. Bad authenticators and unknown types are not included as malformed Disconnect-Requests. |
UnknownTypes |
Specifies the number of incoming requests that have an invalid ID type. |
